Resealing deck to hull joint
DYLBOSS
What is typically used to do this type of thing? I have a few spots on the deck/hull joint that need to be touched up with some sealant. I have a little bit of water getting into the cuddy.
Thanks.
Bob_VT
Re: Resealing deck to hull joint
3m4200 should work fine.
25thmustang
Do you plan to do it from the inside or outside?
