Re: Resin or Epoxy?
CaptMick,<br />Polyester resin is what most boats are made of, it is least expensive resin and the easiest to work with (room temp cure). If you are doing repairs you should use an epoxy, epoxy has good adhesive properties, where polyester barely will stick to itself when wet. Gel coats are polyester based and will have difficulty sticking to epoxy repairs. The reinforcement (glass) you use can be sized for polyester, epoxy or both make sure the reinforcement is compatible for the resin you choose (sizing has to do with how well the resin bonds to the fibers). Good luck.
