Resistance Specifications Stator 9.9 Merc 2 stroke
stopngo
No Spark on either coil so I suspect the stator.
I need to know the resistance specs for each of the three pairs of wires to confirm or rule out the stator as the culprit.
It started fine a month ago.
flyingscott
I would suspect a bad kill switch or.bad. Cdi has the correct testing procedure for.your ignition.
stopngo
If the two wires to the kill switch are disconnected would that be the run position??? IE spark position?
