Do I really need to use Resiweld when replacing the lower swivel bushing on a alpha one gen 2 gimbal ring? If so, is there something else I can use.........really cost a ton for this stuff. Thanks
Resiweld is a high temperature, 2 part epoxy. In the location you're referring to there is no need for a high temperature epoxy (unless you plan on boating in a lava lake )... I'd use Loctite 601, super retaining compound... It should do the same job...
