yorab
Ensign
- Jul 6, 2002
- 960
I'm trying to thread my elec. shift wires through the plate in the exhaust tube now. However, I'm having a problem. The inner cover plate won't get into position due to the inlet water tube being too close to the cover plate. At least that's what I believe is happening. I've attached a few pics. It looks like I need to move that water tube out of the way. I thought that I had it lined up so that the hole in the pipe would spray cooling water onto the wires, and therefore, it should be lined up properly but I suppose I may have been wrong.
1) Is the pipe indeed positioned incorrectly?
2) Can I spin it out of the way without removing the lower unit?
3) I broke the exhaust tube plate gasket. One of the thin sides cracked through, but it still is in good shape except for that crack. In this particular case, can I reuse it? Can I use some kind of Form-a-Gasket for this application?
4) The shift wires have larger-diameter ribs lower down the wire. Do I simply slide the exhaust tube cover plate down just until it seals up against the first rib or does the plate need to slide over a few ribs?
I'm sure that one of you guys that have done this hundreds of times may have ran into this same situation. Thanks.
