yorab
Ensign
- Jul 6, 2002
- 960
Hello. I need to tighten down my flywheel nut to spec which is 70-85 ft-lbs. When I removed it, I used a box end wrench. I put a couple of grade 8 bolts into the threaded holes and wedged a heavy prybar between those bolts while I used the wrench to loosen the nut. Now I need to replace the nut. I can't use the threaded holes because I now need to use a torque wrench and a socket. The socket gets in the way.
I have a strap wrench but it isn't big enough. I tried to use a ratchet strap around the flywheel to keep it from turning while I tightened the nut, but I couldn't get the torque up to spec. The strap kept slipping. I'm thinking of getting a spanner wrench from Sears tomorrow since there is a Sears just up the road. Would a spanner wrench work in those holes in the side of the flywheel? Here's a link to one of their spanner wrenches:
http://www.sears.com/shc/s/p_10153_12605_SPM223959438P?prdNo=5&blockNo=5&blockType=G5
