yorab
Ensign
- Jul 6, 2002
- 960
Motor in signature. Motor has been recently rebuilt. I did not get around to replacing the wiring though. Before the rebuild, the starter seemed to work well. Never had a problem with the starter. A few days ago, I tried to run a compression test but I couldn't get through it because it seemed as though the battery was not strong enough to turn the starter for more than a very short while. I took the battery to get tested and it passed. The battery is 8 years old though so I bought another. I charged it completely as soon as I got home because I read somewhere that it can't hurt to do that. It was almost completely charged anyway. I also replaced the battery-to-junction box cables and cleaned all connections.
I tried the starter with the new battery today because I wanted to test for spark on each spark plug lead. I only bumped the starter for no more than 10 seconds at a time. The new battery seemed like it was having trouble turning the engine over. I could spin the flywheel relatively easily by hand, so I knew that there was nothing wrong with the engine internals. Then I felt the starter and it was pretty hot. I'm guessing that either the starter itself has a problem or the wiring to the starter has a problem.
During my rebuild, I replaced the brushes and cleaned the commutator with emery cloth. I also cleaned the inside of the starter to remove old carbon and crud. I tested the armature to make sure that it wasn't grounded as per the directions in the FSM. It checked out ok. I also checked to be sure that the hot lead wasn't grounded to the starter frame. It checked out.
There is obviously a problem somewhere. If a wire is bad, then I would think that the increased resistance would show up as a greater voltage drop across that wire. Is this the case? How should I go about logically finding my problem without replacing everything? I'll replace all of the wiring someday, but I've got a boatload of stuff to do without dealing with replacing the wiring (pun intended
