yorab
Ensign
- Jul 6, 2002
- 960
Motor in signature. Fresh rebuild. I finally got to go out on the lake this evening. Break-in procedure for this motor requires running at approximately 3000 rpm for the first hour. It ran great at 3000 rpm for about 45 minutes. Then I heard a misfire or something similar. This went away when I dropped the rpm down to about 2000 rpm. I shut the motor down for a few minutes and when I tried to restart, no luck. I pulled the cowl off and noticed that the timing belt was very loose. The distributor bracket had shifted. I guess that I didn't tighten down the bolts enough. I think that I'll put some lock washers under the hold-down bolts. The original set up used only flat washers.
I believe that the belt had jumped a tooth, but I couldn't see for sure because the flywheel guard was in the way. I'll check the timing tomorrow. If this is what happened, could this have caused any damage? I also checked for spark at the starboard plugs but I wasn't getting any. I would think that even if the timing had jumped, there should still be spark on all cylinders. Is this correct?
