Restoration Glastron V156 (The Scarab)
Sn00ky-G
Currently working on a Glastron V156 in Amsterdam (The Netherlands).
Find some sweet (soft) spots in the glastron floor, which let to indeed wrecking the floor and finding rotten stringers.
Sn00ky-G
Welcome aboard ! Let the fun begin !
There is still no fun. Started working again on the boat after two and a half months.
done until today:
-hull patching
-Grinding part.
-Transom placed /laminating tomorrow.
​​​​​- 4x stingers ready for placement
-Inhaled fiber glass / stingy fingers / sore back / cuts and bruises...
An mini update with the pictures see below link ms one drive
https://1drv.ms/f/s!AkfvzYjHlh6f034TbXXHLZdHTH13
sphelps
Good progress so far ! Are you reinstalling the putting green ? :rolleyes:
Sn00ky-G
Haha, if you are talking about the green grass that was put it by the previous owner(s) to cover up the rotting of the floor. Only if the misses wants to plant something in the bow of boat.
Any tips? Iwas thinking about:
-laminating MDF fiberglass and polyester on one side but that’s again a lot of work...
jbcurt00
Not MDF unless its something else in the Netherlands.
MDF: medium density fiberboard
sphelps
Not sure what you are asking . Are you talking about the deck floor ?
Redtruck12
Oh ! You must be looking for the “quick and easy - “
low cost” boat repair section 🤣👀
Sn00ky-G
Owh my, miscommunication... The deck floor should indeed be made of triplex and not MDF. Laminating triplex
-laminating one or both sides?
-Laminating will give it a rough surface, any tips on making it more smooth or other tips for getting the deck waterproof childproof and strong?
Im indeed searching for the best low cost and fast way to fix it... I normally work with figures and computers only. Fixing a ledger is way easier than fixing a boat...
Again a mini update: (please note: that I’m first timer)
-Laminated the transom.
-Placed two stingers with fiberglass putty.
Sn00ky-G
Hi Guys, busting my bals here about ->
After placing the four side stingers, I want to remove the middle stingers and laminate the four stringers without the middle to give the middle of the hull some strength?. Afterwards I will laminate it one more time with the middle stringer.
Would the above be a good idea?
sphelps
Yes I would glass the underside of the deck ply before installing ...
Nothing wrong with how you want to do the stringers ...imo
Sn00ky-G
Sn00ky-G
Another update from AMSTERDAM:
-Removed the middle stringer
-glassed in the 2 side stingers with 1x csm 450gram + 1x 435gram
-glassed in the 2 middle side stringers with 1x csm 450gram + 2x 435gram
Glassed in the middle/center of the hull touching the 2 middle side stringers with 2x csm 450gram (U-profile)
On schedule tomorrow:
-center stringer placing with putty, glassing 1x cms 1x biax
-other hull patching+glassing:
Upcoming problems:
-stringers placed to high, they height of the stringers matches exactly the top of the old floor. (Any solutions / tips)?
-The sides of the top cap and lower part has a lot of holes near the edges looks like a cheese hole cap( Any solutions / tips fixing these)?
-Paint job, any suggestions what to do? As I can’t figure out if it’s bad?
Enjoy!
sphelps
Either raise the deck height a bit or cut the stringers down ..
depending the size of the holes you can fill with your bedding / filleting mixture and sand ..
Painting ? Just depends on what you want to spend really ..
sphelps
Looks like it just needs to be sanded smooth . A bit of touch up fairing then primed and painted . Probably don’t need yo take all the gell off ..
