chuck in WA
- Aug 3, 2004
- 105
Hi All,<br />I've been eyeballing wooden runabouts for some time now, and have considered building an 18' inboard Glen-L design called Miss Mist. I've been putting it off, as I'm not sure I have what it takes to do a project like this. My boat building experience is limited to a 17' stitch and glue kayak, which I had a great time building 3 years ago. Fast forward to last week when I found someone within a few hours drive selling a Miss Mist hull (no engine or hardware) built in '62. I figure a restoration project such as this may be more appropriate for my skills than new construction. According to the owner, the bottom has a hole in it, but the frames, keel, battens, and stem are all in great shape. I haven't seen the boat or any pictures yet, but before I put too much thought into this and make a road trip, I'd like to get an idea of what I would be in for. I think I can handle the wood/epoxy/fiberglass work OK, but I know next to nothing about inboard engine and drive component installation. I suppose appropriate power for this boat would be a V-6 or 305 or 350 V8. The owner says it was originally powered by a 292 Ford "y" block. Some questions:<br /><br />1. Would any of the new engines listed above fit the mounts already in the hull from the 292? If not, would I be able to use some type of adapter plate, or would I have to install new mounts? Does this depend at all on the transmission selected? <br /><br />2. What cost would I be looking at for an entire driveline to include new or rebuilt engine, tranny, shaft, prop, rudder and exhaust? I've seen remanufactured engines go for about $2000, but have no idea what a whole new/reman setup would cost. I'd lean toward a fuel injected, fresh water cooled motor depending on cost. Where have you guys ordered your parts from?<br /><br />3. Any good books on the subject of inboard engines you'd recommend?<br /><br />4. Other inputs?<br /><br />Thanks a bunch for your advice guys - this seems to be an exciting/challenging/rewarding project - I just want to make sure I don't bite off more than I can chew!<br /><br />Chuck<br />PS - sorry for the long post
