Restricting Water Outflow in a 40hp Johnson
Sculpin67
I've decided to add a SE hydrofoil to my 2 stroke 40hp Johnson. When I put it on, I'll restrict the outflow on 2 of the 6 water outlet holes, but they will not be totally blocked. Is this a concern? I can shave a little material away if needed. I'm hoping that with water coming out of the 4 holes, the prop and the telltale hole, I should be go.
I have the motor mounted on my 1677 Lowe CC, so it's underpowered. I have problem getting on plane, especially with a full load. I do have a prop with the correct pitch....
Daviet
Re: Restricting Water Outflow in a 40hp Johnson
You will be fine, woun't cause any problems.
