Re: Results of boring
The intake ports on the tripples aren't ramped Through the sleeve for just that reason-they will stay the same size (for the most part) clear through max over-bore. Yea, I know, they "grow side to side".<br />OMC recommended a .001 jet change at .030, and above, only if plug color showed a lean condition.<br />I know you are the engineer, but I also understand the low pressure area thru the venturi, with the same carb, enlarging the displacement creates an even higher volume of air thru the venturi, pulling "some" extra fuel as well.
