i have a 1975 johnson 85hp 4cyl. I have changed the rectifier because the wires were melted. today i hooked it up to a battery and turned the key! starter works. crank spins and a copression check shows 100 on the cyl on the left. and 105 on the ones on the right. then i held the plug in the wire and grounded it on the head and no spark. changed plugs and no spark. put a test light on the screw that is identified as coil 1, 2, 3, 4, (on the rectangular box between top cylinders on back side of motor) and no light while turning it over. how should i be checking for spark? also i had to replace the small buss fuse that is conected to the recifier and blew it again. the third one still in tact. the ones i bought were 5 amp. any suggestions of what to do next is greatly appreciated. (shop manual is on order, the one i had got wet before the motor did)
