Having to replace the carpeting on a 1990 pontoon that has it for quite a while. The surface of the decking is peeling up on a couple of sheets, BUT the floor is not week. Can this decking be resurfaced or should I just bite the bullet and replace the plywood? I'm really not wanting to replace it unless absolutely necessary because this pontoon has the decking sandwiched in channels, so I will have to remove all the bolts on the cross struts to be able to get the plywood in between. It also appears that the sides of the plywood have been trimmed down a little all along that framework to fit in the channel as well.
