Reupholstering seats
JThompson28
Looking to reupholster seats in a 26 ft pontoon. Lots of seating. What is the most economical foam I can use ?
The propper marine closed-cell seat foam.
Mechanicalmike08
I bought mine on Ebay, it was the best price and came in a variety of thickness and lengths. Just search marine high density foam. there was not to many sellers when i was looking but they beat any stores i could find.
What thickness ???
what thickness do you have now? you would want to match.
are you planning on sewing the vinyl yourself? If so, you need to have a good capable machine. you can do it with an older Singer 15-91, however any of the newer plastic machines are not up to the task
Plenty of threads about sewing and upholstering, many by Woodonglass
JThompson28
Thank You 😊. I’m not sure what the thickness was 😞 seats are so disintegrated there is not much left.
Woodonglass
I'd recommend 5" HighDensity.55 lb compression.
https://www.ebay.com/itm/FOAM-SHEET...hash=item215469883b:m:mIDfUsjjpNaCwlDVaU91FjA
You'll also need to use V-92 Polyester Thread with a #18 needle.
Industrial Machines are BEST but as stated the Singe Model 15-91 will do the job and they are usually found on Craigslist for under $100
Lots of GREAT instruction on YouTube. SAILRITE Company and this guy.
https://www.youtube.com/user/Cechaflo
Even though he doesn't do Boats his techniques are the same and he really knows his stuff
harringtondav
I'd go with Woodonglass and purchase high quality foam. The extra cost is peanuts compared to the effort of tearing off your covers later to replace flat foam.
