Reusing the oil pan gasket
Evinrude Boater
While assembling my new engine a tool fell into the distributor hole and I had to take the pan off to retrieve it. Can I reuse the pan gasket. It's a Victor Reinz gasket made of a plastic material with metal grommets at the bolt hole locations. Thinking about gear case fill and vent screw gaskets, I'm wondering if the grommets crush during installation preventing re-use.
dubs283
Re: Reusing the oil pan gasket
i would think its okay
just be sure to clean everything and a thin bead of RTV would not hurt - definitely at the seal/timing cover corners
Evinrude Boater
I used RTV at the corners and Permatex Aviation Form-a-gasket No 3H on both sides of the gasket. Manual calls for Perfect Seal. The Permatex Aviation is pretty much the same thing, isn't it? I've cleaned it all off with solvent and scraped as much of the RTV off the gasket as I could with my thumb nail.
dubs283
perfect seal isn't going to aid sealing on a rubber or plastic gasket, its designed for fiberous gaskets
you will be fine with what you did
Don S
Gaskets are not reusable. or at least they shouldn't be considered as reusable. But what the heck, give it a try, if it leaks, all you have to do is pull the engine again to replace it.
Read the blue part of my signature.
VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
Evinrude Boater
I re-read the manual and it seems to refer to using Perfect Seal with older 4-piece gasket sets. What's required with the new one-piece moulded gaskets? Just RTV the corners?
mrchev
if it is a stiff plastic gasket with steel grommets then it can be reused.just put rtv in the corners near the seals in front and back.
Don S
no way, man
gotta run er on the floor before install!!
running on the floor doesn't get the engine oil as hot, or bounce around and make turns like a boat does.
I really don't care if he changes it or not. I don't have to fix it.
Evinrude Boater
While I've still got it open I might as well verify that there's no gasket on the oil pump mount. Is that right? (87 4.3 liter)
lime4x4
If it's a 4.3 liter engine then that gasket should be one peice. molded rubber with metal inserts. In the automotive world that gasket is re-usable as long as it's not damaged. Gm shop manuals tell u it can be reused. Also on a side note. Alot of the newer cars/trucks are being built with re-usable gaskets.
Don S
In the automotive world that gasket is re-usable as long as ................
Maybe you missed something, this is a boating forum. Not a car and truck forum.
Small minor leaks that wouldn't even be noticed on a car or truck, will be evident in a boats bilge, and when mixed with a little water can make a nice mess.
Besides, who in their right mind would want to reuse a 25 year old gasket, doesn't matter what it was in. Seems like a common sense thing to me.
Don S
I think he is asking if he can re-use his new gasket that he just installed.
uhhhhhhhhhh, mmmmmmmm, Well, :redface: oops :redface: :redface: :facepalm:
In that case, sure he can reuse it, it hasn't even went through a heat cycle at that point.
lime4x4
i make my living turning wrenches. Very few gaskets are esp made for the marine engine. Felpro makes most of the gaskets for gm engines. There not going to make a special marine oil pan gasket. I assumed the original poster used a new gasket.. On a side note i've resued oil pan gaskets on $70,000 corvettes that had a few thousand miles on them. and the cust never came back complaining of a oil leak. And those people are picky
ENSIGN
mercruser gaskets are made by felpro!
Evinrude Boater
My gasket is new, never run the engine. It's back in the boat. Wish me luck.
