Rev. Limiter Diagram 1960? 40HP Big Twin
KirbyE
I'm looking for instruction for wiring my 40 hp. I think it's a 1960 Evinrude 40 HP. "Big Twin". Model 35520 S# 23821. (If you can check this, or link me to the chart, that would be great).
I'm rebuilding from an old project and I have nothing to go by. The spark is hot on both plugs.
I am converting to electric start, so I'm fabricating new wire harnesses for most of it. I understand (from memory) there is a vacuum / pressure switch on one intake plenum (looks like a fuel pump, except for the wire) that cuts one cylinder in the event of over revving. There also appears to be a "mercury" switch on the thottle assembly to sense WOT or high throttle. I need a diagram of how this is wired so I get the correct cylinder with the switch strategy etc. The rev. limiter seems like a good safety feature to have, in case I shear a prop, or whatever. I also plan to add a tethered cut-off switch. (this is easy, close the two).
I recall reading a page somewhere that described all this in detail. It may have been in one of the shop manuals. If there is a link to that page, or something similar, that is what I would like to have.
All input is welcome, and thanks in advance.
(OBTW: the starter gear seems to only meet half the ring gear. The flywheel is off another motor, and it is the correct shaft dia. Is this OK or do I have something wrong? It looks like it will work fine, just not using as much gear tooth as available). Thanks.
Chris1956
Re: Rev. Limiter Diagram 1960? 40HP Big Twin
Those motors usually had a safety switch to keep 'em from starting while in gear. It cut the power to the starter solenoid.
The starter solenoid was in a box that was to be mounted in the boat. The box also contained connectors for the ignition, hot light and generator wires.
KirbyE
Many Thanks to CATransplant for the search results.
I still have a few questions:
What is the "Safety Switch" the Vac Cutout Switch? Is it the safety mentioned by Chris1956? ( I don't have one, but I plan to add one). I don't see how it's wired if the corner bolt on the Vac switch is a grounding point. Isn't it? Or does it open the ground path for the solenoid?
Is there any way to test the Vac Switch? I guess it doesn't matter which cylinder it's in if both wires go there.
What are the items that look like gravity (mercury) switches on the throttle linkage? Are they to prevent starting at hight throttle?
(I don't have choke solenoid, or generator, or the box with the starter solenoid, but that's no big deal. I will hang the solenoid in the same place I did on the 35hp.)
Thanks again,
HighTrim
This may help
KirbyE
Many thanks to all who contributed ! You guys are great. I hope one day I can give back. I'm wired up and in good shape. I will run her in a barrel this weekend. Anyone shopping for a solid used one? I'm in 18940 and I really don't need this thing.
