rev limiter is 6700 where should i be at wot
Dhadley
Re: rev limiter is 6700 where should i be at wot
Depends on your hull. If it responds to propeller rpm then take it on up. If it's something like a Hydrostream which does you can by-pass the limiter and probably gain some speed. If it's a heavier, non-pad hull then somewhere around 6000 will probably be best.
