I agree that 1500 RPM is about all you want to do while running off of the hose. A good way to tell if the engine is getting enough water is if the muffs are still spitting water out the sides, then you have enough pressure/flow going. If the muffs are not spitting any water while the engine is running, then you may not have enough going to the engine.
