Re: Reverse chine aluminum boat ride quality?
I'm curious, how do you figure an AL boat is cheaper/easier to repair than a Fiberglass boat?
As for ride quality, deadrise determines the ride in rough water more than chine design. Chines are for cornering and planing performance.
I guess that depends on your skills and equipment. I can weld up a small hole and cut it smooth in minutes. Dents are a little harder, but a hammer and a hand anvil will fix a lot.
Not everybody has a nice MIG sitting in the shop already setup for welding aluminum, but a not a lot of people have all the fixings to repiar fiberglass either. Just so happens I have a few yards of glass, a bit of both epoxy and polyester resin, and a bag of ground glass sitting out in the shop.
The couple grand I spent for my welder certainly costs more than a brush and a squeege, but the prep time to weld aluminum is minutes, and when its done I can grind it and put it in the water right now.
Labor time, and tying up the floor in my shop is the killer for a glass repair.
For the average single home repair it might actually be cheaper to do glass if you do it right, but resin isn't cheap either. No welding rig to buy, but then a tiny TIG rig could do it with some care. Might even be the better choice for some small work.
If you take the work out to a shop a friendly welder can reweld a cracked weld or patch a pinhole in minutes while you wait. Not much more time and they can even weld in a reinforcing brace. A proffessional shop will probably even have grinders laying around already chucked up with stainless steel brushes just for prepping aluminum. I have a home shop, and I have one angle grinder hanging on the wall with a stainless brush that never sees anything except aluminum.
More involved repairs for either glass or aluminum are just that. More involved.
