Re: reverse gear
I am on my 3rd lower unit and can tell you from hard earned experience if you want it to be reliable pony up the money and have it done right.
If your tolerances are of just the slightest bit out it may last a year or two.
Tha first time it went it was the clutch dog exploded,HARD prop strike, got a new one, then reverse threw teeth,bought a crusty old lower from a marina and put that reverse in with my old gears.
Then I threw the teeth off the forward gear, bought a new gear set($320)and that lasted a year before it went again, teeth forward gear.
Then I bought a used lower off Ebay WITH a prop for $142 bucks( I about fell out of my chair when I won that!) and haven't had any problems since.
The first failure was inexperience on the river I fish, the rest were because I tried to do it myself, mix and match parts ect.
Oddly enough all except the first went at WOT in deep water,horrible sound it is.
So the moral of the story is, as much as it sucks ,pony up the money and have it done right at a marina or say your prayers and surf over to Ebay and see if you can get lucky.
I spent just as much money and had way more down time than if I had had it done right in the first place.
