Re: reverse lock
Those are Not the Symptons of a faulty Reverse-Lock,........ That would be the Drive Jumping Up in reverse.............<br />Or something Exploding from Excessive Pressure when you Try to trim Up............<br />I Think if you unplug the 2 wires,.. It'll ceace to function.........<br /><br />Your Issue sounds like Dry Pivot Pins......Something is Siezed,.. Or about to be.........<br />The Trim Pump,... Pumps Up,+ Out..... Gravity,+ drive Thrust Push it Down.............<br /><br />The Pump makes High Pressure on the Up,+ Out side,.. But Considerabley Less Pressure on the In,+ Down side........
