Reverse Lockout Soleniod Installation Question
thompsdw
I recently added a reverse lockout soleniod (connected to my reverse light) install on my trailer boat. I spliced the soleniod into the brake line and ran the 12V line to a newly installed 7 prong plug on my auto.<br /><br />Here is what happened. At first the soleniod seemed to work fine with no problems. I was able to drive forward with no issues and was able to backup with no problems. Did this for a while and while driving down a steep hill I attempted to back up and the brakes locked up. After this, the brakes were locked in either direction. Basically, there was pressure behind the solenoid (brake side) that did not dissipate. I am assuming that the solenoid did not open back up. I bled the pressure off of the downstream side of the soleniod, cut the 12V supply line and went boating.<br /><br />I don't understand why the system worked normally and then suddenly locked up. The steep hill was the only factor that changed. Are these soleniods directional? There is no marking on the soleniod, however, the hill would have caused much higher braking pressure than previous. I was wondering if reversed, if this pressure could cause the valve to not open.<br /><br />I am clueless other than this theory. Please help.
JB
Re: Reverse Lockout Soleniod Installation Question
Duplicate. See Trailers.
