Reverse Manifold Vacuum? What?
jbarraclough
Help me figure this one out. I posted recently a small block Chevy crankcase pressure problem. Good compression (130-150) all around. PCV valves functioning properly. No noticeable smoke from the exhaust (maybe a little more than the other engine). Major blow-by. I tested the manifold vacuum at the base of the carb. Results? 15-16 PSI at idle, 20 PSI at 2000 RPM. How is that possible? If it's a stupid mistake on my part, I apologize but something is causing this blow-by and I'm going nuts trying to figure it out. Any ideas? Thanks.
echozulu
Re: Reverse Manifold Vacuum? What?
how do you fiqure 130-150 lbs is "good compression "? its ragged out tear it down
snapperbait
Jbarraclough, when you checked the vacuum you read positive pressure in the intake manifold in PSI, correct? Or, did you get a reading from a vacuum gauge in in.HG (vacuum) in which case 15-16 in.HG would be about right...<br /><br />Have you done a leakdown test with compresed air on the engine? That'll help nail it down to a piston, rings, valves not closing, ect...
conimicut1
if its driving you crazy get a leakdown test, much better than a compression. Finding a tester may be a little harder, check a rebuild shop and promise to take the engine to them for a rebuild if it needs it later.
mabbott
Compression of 130-150 is fine. echozulu, what makes this so bad? The brand new spec. is probably 150 right. Vacuum of 15-16 isn't bad. Try ajusting the carb to reach the optimum maybe 18. I would expect the vacuum to increase at higher rpm since it's drawing more air.
