Reverse Problem
skipper1984
Hi all
i need some help diagnosing my reversing problem, i suspect it's something to do with the tilt and trim basicaly when i put it in reverse and apply power the engine lifts out of water any advice on what it could be and the bet way to fix it with out paying fist fulls of cash to the local marine mechanic,
many thanks skipper1984
achris
More fish than mountain goat
Re: Reverse Problem
... any advice on what it could be ...
Without knowing what engine hp and year, or better still a serial number, not a chance in the world....
Chris..........
skipper1984
Re: Reverse Problem
I fail to see why people would need my engines HP rating, year model and serial number for a little piece of helpful advice, how ever if you realy need to know and if it would help to cure your rudness to newbeis, she is a 1979 mariner 70hp and i fail to see why you need a serial number to simply say it sounds like ......... or it could be.......... but any ways if your reponse is the norm for this forum where the so called "captains" are rude has hell to us newbies who would rather be on the water than sitting on the net boasting about their vessels,than id rather not be apart of it.
achris
Re: Reverse Problem
I'll apologize for my 'rudeness'...
However... Why we need engine type, hp, etc... is because different engines use different methods of 'reverse lock'...
Help us to help you....
I answer A LOT of questions each day, and many people, newbies and oldies alike, appreciate the fact that the mechanics here give their time, freely...
Read JB's 'sticky' at the top of this forum....
Chris..........
fletcher
Re: Reverse Problem
good call achris.i am new to this forum.like yourself and a few others on here,you know your stuff and i appreciate your time and advice:)
383cross
Re: Reverse Problem
I have the same problem with my boat yesterday, tried to reverse away from the dock and when my brother tried to back up the motor kicked up and about hit me in the head. it's a 85 Bayliner with a 76' 65hp mercury. I know there are locks to prevent this that arent working but I havent figured out what makes them lock, I assume that when you engage it in gear these fingers lock on the trim/tilt bar to keep the motor from lifting in reverse. Any ideas what activates fingers? I cant find anything to trigger it, hopefully I dont have to tear the motor apart (again) to fix this. Any help would be greatly appreciated.
achris
Re: Reverse Problem
You need to ensure that the motor is lowered down while in forward gear. That lifts the 'fingers' that lock onto the rod. When you move to neutral or reverse the fingers drop onto the rod and stop the engine kicking up... If you lower in neutral the fingers are already down and don't lock properly....
Chris.......
