Reverse Problem
seulb
I have a 1971 mercruiser 2.5 GM with a type 1 sterndrive that runs great in fwd. but when shifted into rev. the eng. stops running, what could cause this problem? Thanks
Re: Reverse Problem
Ayuh,.... Odds are the lower shift cable is Draggin' causing the shift switch to stall the motor...
The Fix is, Replacin' the lower shift cable...
