Reverse solenoid
FourWinnsLC
I need to replace this solenoid, but all i can seem to find are 1/32 orfice solenoids. Is that going to work on my set up? Do i need a change over?
thanks for the input!
dingbat
Yes, it will work with your setup.
Fit, form and function replacement for what you have now
FourWinnsLC
Ok, replaced the solenoid, still can’t back up. I verified I have power to the solenoid.
what should my next next trouble shooting step be?
Lightwin 3
Your solenoid can be fine but if there is air in your lines, it won't work. Neither will your brakes.
dingbat
If you hear a click the solenoid is working.
Blocking solenoids are a pain. Not the most effective method to begin with.
Replacing the solenoid introduced air into the system. Will take darn near a bottle (small) of brake fluid to bleed properly. System will not work properly until you do
FourWinnsLC
Good stuff, I do have breaks though. Should I still bleed the breaks for the solenoid to work?
great day on the lake either way 😎
