I've recently acquired a 1990 Phantom boat with a 5.7 OMC, 4bbl Holley, and straight thru-hull exhaust. It's been sitting on the dock untouched, not started, for at least 10 years, and was only run a couple times a season prior to that. It has 119 hours in 22 years.
Naturally, my first step was to pump out the gas tank, flushed it with a few gallons of fresh gas, then put fresh gas back in it. New fuel filter, primed the carb, and started right up. Took a little while for it to idle right but it gets better every time. Changed the oil, currently working on outdrive lube. What other steps should I take to have it back to weekend warrior status? Spark Plugs, wires, points, water pump impeller? Thanks
