Revolution 4 Question for Baja 19' Islander
ThndrSki
1) Current SS prop is allowing Engine to Redline.
2) Michigan Wheel, Apollo XHS, Stainless Steel.
3) 14 3/8 diameter, 18p
4) 4800, Speed Unsure of as I have never GPS'ed it.e load (very helpful)
5) Mercruiser, 350 Magnum 5.7L Alpha One, 1995, and 250 HP
6) Baja Islander, 1996, 19' 2800 lbs
I have a Michigan Wheel, Apollo XHS 18p 4 blade SS that has great hole shot, but is letting me get to 4800 RPM which is too high. I have a 19ft Baja Islander Bowrider with a 5.7L Mercruiser Alpha 1.
I have the opportunity to buy a damaged Revolution 4 SS 19p prop part#48-857026A for $300. One of the blades is bent, and another has a chip out of the leading edge.
Question #1 is, is this too much? How much would it cost to have it repaired and should I pass on this prop?
Question #2 is, am I looking at the correct step up in pitch/prop from my current 18p prop?
Thanks!
tpenfield
Re: Revolution 4 Question for Baja 19' Islander
Thanks!
Answers:
#1 Yes, way too much. Pass. You can buy a new one for less than the total price that you would pay.
#2 I would expect that you will be at about 4600 RPM with the Rev 4 19P and maybe 4200 RPM with the Rev 4 21P. Take your pick.
steelespike
My info checked over several listings is the rpm is 4800.
As far as a prop change we need the info asked for in "read third first" at the top of the prop forum
to make an informed decision.
ThndrSki
Thanks - I have updated with the info from the read me first.
Tail_Gunner
Aside from the revolution what is your goal. 4800 is not to high but it is your engine what would be your target RPM....There are a few props that are far less than a merc and provide performance above that par. A 4 blade 19p Solas HR titan should put you right at 4600 or a 20p 4 blade stilletto in a baypro 11 at 43-4200.
