Re: rewinding stator 398-5704a4
did you count windings very carefully and make sure you have the direction right. the factory plastic from what i can see by pics, is to protect the windings and make them look more complex than they really are lol, I would guess it also provides insulation and some structure to them.
that said if the winding are replaced with insulated (enameled) copper wire of the same size and the same number of windings in the same orientation... and wound as tightly and uniformly as possible. you could likely use spoxy to protect them. windings are simple to construct, just make sure you duplicate how they made em. You may want to poke about on the electric motor forums where they talk specifically about this very topic (proper winding)
Sean
