Rewiring trim/tilt motor control
Status
Not open for further replies.
Efini Motorsport
After everything I've done on my boat the trim/tilt relay decided to crap out on me. The relays still click but I'm not getting any voltage on the wires to the pump. If I run 12v to the pump it works as it should.I haven't pulled the box yet to see if I can open it up and check it out internally. Is there any reason I can' t wire in two relays to control the pump? The boat is a 90 Four Winns with what used to be a 4.3 carb motor. It's now a 4.3 fuel injected Vortec but all the drive stuff is still original OMC. The pump has two heavy gauge wires, blue and green.
kenny nunez
There has to be a fuse that feeds the power relays for the trim motor load that is usually located near where the main battery cable mounts on the starter. It looks like a square block. it is separate from the fuse that supplies power to the trim switch.
Efini Motorsport
Mine had one box that supplies power to the switch and the relays and has a circuit breaker on the front of it. I can hear the relays clicking going up and down but I have no power at the terminals that go to the motor. It may be a bad trace inside the box. I'm going to open it up tonight and see. I've rewired the entire boat so things on mine are routed a bit differently. The trim/tilt circuit is about the only original wiring left in the boat. It's wired straight to the battery so I don't have to turn the main switch on
Status
