Re: RF ground..
All models of depth finder made by Furuno have a static ground. Its not an RF ground, as you'd find used to establish a ground plane for a radio receiver, its just there to disapate the potential caused by static. Very few folks connect them to anything at all and most of the folks who do hook them up do more damage than good because they connect them directly to an engine mount. That provides a direct link to any stray currents caused by bad spark plug wires, bad alternators, and a host of other electrical gremlins that might be found in the motor.<br /><br />If you do decide to connect it to something you could go directly to a metal thru hull but even this is to be avoided if your boat has a bonding system. The best bet is to use something like a Dynaplate (a small plate that attaches to the bottom that is made from sintered (sp?) bronze made just for this purpose). <br /><br />The real point is that unless you find the depth finder has a lot of strange little blips and streaks on the screen, particularly if you find that they flicker, the thing really isn't needed. In fact even in those cases you will almost always be better off by filtering the power supply, something you can do for about $6 with a DC power conditioner straight from you local Radio Shack.<br /><br />That help any?<br /><br />Thom
