Rib eye recipe
one more cast
Today I am going to roast a 6 lb rib eye roast.This is something I have never done due to the price of these babys. My question is, Who has the best recipe? <br />**************************************************<br />OMC
roscoe
Re: Rib eye recipe
Roast very very slowly, with low heat. This will allow roast to heat through at an even temp throughout. You will not overcook the ooutside before the inside is hot. Use a thermometer, don't overcook. This is a steak in roast's clothing!!!<br /><br />Season the heck out of it with all your favorites.<br />Remember, these seasonings will only be on the outside edges when you slice it, so you can over apply spices with no ill effect.
mellowyellow
Re: Rib eye recipe
I personally use an electric roaster for roasts,<br />but a good old roaster pan in the oven works well<br />also. very simple, cook it on low heat for a long time.<br />if you like it med. rare, about 20 min/lb. at 300<br />in a preheated oven, 30 min/lb for medium.<br />I don't like to cover the flavor of a good roast<br />with anything more than salt/pepper.<br />some cleaned taters, carrots, onions, celery<br />thrown in the pan and your done.<br />oh and it's a good idea to tye it with string<br />before you throw it in and put it on a little<br />roast rack so it's not laying on the bottom of<br />the pan.<br />you'll be shocked how much it shrinks!<br />enjoy!<br />M.Y.
mellowyellow
Re: Rib eye recipe
if you use the roaster pan in the oven, don't<br />forget the lid! you probably already figured<br />that out, but hate to see a beatiful roast ruined.
Hooty
Re: Rib eye recipe
1. Tie it up<br />2. Roll in salt, black pepper and a little garlic powder<br />3. Sear all the outside fast it in a big, hot iron skillet<br />4. Roast as above<br /><br />c/6<br /><br />Hooty
ob
Re: Rib eye recipe
Hooty's got the ticket.Searing the outside first will keep the juices within the roast while cooking.You can always tell a good beefeater when you hear one.
