Re: rigging temp alarm
You have a temperature alarm built into the ECM for overheat. The ECT sensor talks to the ECM and in an overheat will sound the alarm.
Your oil pressure alarm is NOT through the ECM, and neither is the gear lube reservoir. The wires on the sensors are at the end of the line and are a ground, not power. Power comes from the igntion switch purple wire for power to the buzzer. When the sensors close due to low oil pressure they complete the ground and the alarm sounds.
Look at your original oil pressure switch, it should have a tan/blue wire going to it. That is ground from the buzzer. If you take the connector off the switch and touch the wire to a clean ground while the ignition switch is in the run position, the alarm should sound.
