Right Gasket for Volvo Penta Gear Case Cover
dmwelch
I've recently acquired a 2008 Stingray 185 with an SX-ALT42 drive and I was doing the routine maintenance check, unfortunately I got carried away and stripped the Bearing Gear threads on the cover (Part #3840848-2). I did not strip the dipstick itself. I was able to take it off and and helicoil a new 1/2 - 13 thread back into it, yes, I did keep track of the shim. Now I'm reassembling it and I have couple of questions:
- Should a sealant be used around the new gasket (Part # 3889782) If so, what kind is best.
- What is the torque on the four bolts that hold the cover (Part #3840848-2) and do you use any sealant on those, it appears to have some white sealant on it when I pulled them off.
Looking forward to getting your input,
Thanks
David
Fort Myers FL
muc
"Retired" Association of Marine Technicians...
Gear lube on the gasket.
Light coat of Mercury perfect seal or permatex form-a-gasket #3 on bolt threads.
Criss cross pattern , 6-9 ft lbs first pass 15-20 ft lbs finial pass.
Note; inspect the cover VERY carefully for a small crack near where the dipstick screws in. 9 times out of 10 I find a crack there when the threads have pulled out.
muc
For reference.
The drain and oil level plugs are 60-84 in. lbs
the dip stick is 48-72 in. lb.
