Right place for Hydraulic Bennett Trim Tab
strikemike
I bought a new set of Bennett Trim Tabs. Bennett says you should attach the flaps parallel to the hull. But I have now also seen many fast boats where the trim tabs are mounted horizontally.
The bathing ladder, depending on the installation of the Trim Tabs in your way ... Is it possible to cut?
thx
mike
Ayuh,.... Go with the green marks, 'n tell swimmers to keep their feet, Off the tabs,.....
You won't be at all happy if ya mount on the orange lines,...
Tabman
iboats.com Partner
The green location, parallel to the bottom of the hull is the correct location for your boat. The other location would not work at all.
