I have a Bayliner 185 2007 with the Mercruiser 4.3 litre the drive is Alpha 21.81 Ratio D Drive 1.8
I cannot read the propeller part number stamped on the prop except for the last part which is A45P23Mercury. I am assuming that it is a 23 pitch it is alloy and I believe a standard prop, I want to reduce the pitch for better acceleration for Water skiing and towing for young and old, at the moment it takes along time to pull people out, would a 19 inch be acceptable and is it ok to use?
I would appreciate any suggestions I do want to go to a stainless prop also
Thank you in advance for your assistance
MJ
MJ
