Righty tighty-- lefty loosey ? Drain plugs ??
Hey sea hound jockey's , got a question for ya's . On the 3.0 merc 181 iron duke GM motor. Do all of the water drain plugs open in the same pattern as a common theaded bolt?? Righty tighty -- lefty loosey?? I just don't want to snap a bolt head or strip something out.....
Sea Hag -out!:):)
Bt Doctur
Re: Righty tighty-- lefty loosey ? Drain plugs ??
you are correct .
Also , on the manifold drain plug ! Is this the bolt located on the bottom of the manifold near the middle?
Thanks for your reply
Sea Hag out !:):)
Thanks Don S. Got a bunch of good data from Mercury service manual not covered in my Seloc manual . And a ton of good photos as well ...
Keep up the good water work!
Sea Hag -out!:):):D
