ringing noise at 3000rpm, 6HP 2013 model year
MattFL
Master Chief Petty Officer
I just picked up a new 2013 model year 6HP Tohatsu 4-stroke with integrated fuel tank, and I've got just over 6 hours on it so far (installed a tach + hour meter before running). It's on a 13' aluminum boat with a wood-encased transom. Right about 3000 rpm it starts making a loud noise that is hard to explain, more of a ringing than a screech, but very loud. Below 3000rpm there is no noise, and by about 4000 rpm the noise is gone. It only happens in forward gear, not in neutral. I have been unable to isolate what part of the motor the noise is coming from. I ran it with the cover off and there was no change in the noise at all, volume or pitch. I thought it might possibly be the boat, but the transom is covered both front and back with wood, and I've been unable to identify any part of the transom that is vibrating at that pitch. The motor runs absolutely great, I'm just concerned by the noise and I'm wondering if something is wrong or if this is just a trait of this motor. Does anyone else with a 6HP notice this same noise at about 3000 rpm?
MattFL
Re: ringing noise at 3000rpm, 6HP 2013 model year
Thanks, I am very hopeful that you are correct. :)
TOHATSU GURU
It happens usually on aluminum and steel hulls. Even though you have wood pads you still get that harmonic unless you add additional padding to it. Try a piece of rubber or carpet to help it out.
MattFL
It makes sense, I guess I was just surprised by how loud it is when you're in the boat. The entire transom is covered with wood, not just a little block for the motor. 1" thick on the back and 1/2" thick on the front. That ring is so loud at the right RPM that it almost hurts my ears. I'll try some carpet under the motor and see if that damps it some, thanks!
