Previous owners used the boat in salt and brackish water, but dry stacked between uses. 94 original hours currently on the clock, verified by ECU scan. Manifolds and risers look to be original. Before splashing for the season this year, I plan to pull the risers to inspect for corrosion.
What's the difference between the full flow and restricted flow gaskets? The engine is raw water cooled, and use is only during spring and summer in NE US, fresh water.
Engine serial 0W635474.
