john everett
- Feb 27, 2004
- 3
I am replacing exhaust manifolds and risers on my 1988 bayliner ciera 2556 (5.7 cobra). The previous owner changed the original end rise manifold to a center rise and added an extension. The change required that the engine hatch be changed from flat to raised (box) and the cooling system moved to the other side of its bracket. conciderable trouble. Was there a problem with the factory riser height? Is there a spec for height of riser above static water line? I would like to go back to the original mainfold and riser and a flat hatch if there is no problem in doing so.<br />thanks for any help <br />john
