Should the risers/manifolds be changed at set intervals or do you wait until there are signs of problems. I have just bought a 2004 Chaparral with 4.3L Mercruisers. The boat is used in salt water six months per year. The engines have 195 hours and do not run hot. There is a little condensation around the base of the riser. My surveyor suggested that I have some inspect the riser at the end of the season. I spoke to a mechanic who said that once he does the labor to remove the riser for inspection, I might as well replace them. Should I plan on doing this on a four year old boat. I assume it will be expensive.
