Re: Riser studs
from the manufacturing side, yes the bolts are cheaper. Until you get into weird sizes, when it becomes cheaper to use studs if you have the capability to make them correctly.<br /><br />One less important but reinforcing reason to use bolts more often is 'the lowest common denominator'. Almost any idiot can put a bolt in correctly. More of those same idiots will fail to put studs in correctly. Simply put, manufacturers tend to try to idiot-proof the parts as often as possible. When that route is cheaper as well, they will most assuredly go that way.
