I am rebuilding my rochester 2bbl carb and found my main acceleation hesitation issue. The inlet check ball for the accelerator pump is jammed not letting any fuel into the accelerator pump. How can I remove this check ball? I have tried:
1. PB Blaster
2. Carb Cleaner
3. 125 PSI of air pressure on the other side to blow it out.
4. Drill it out, afraid I am going to go through the carb body because the ball is harder than the body.
1. PB Blaster
2. Carb Cleaner
