I just finished rebuilding my Rochester 2GC, electric choke for my '76 Ford/Mercruiser 302. Not to bad of a job, but I'm having brain block. Everything went smoothly until I went to re-install the linkage on the carb. The choke plate has spring tension to close applied by the choke spring. At the same time, the linkage does not flip the choke plate open as the throttle would open up. This is the one thing I failed to make note of when I disassembled it. Does anyone have a diagram or picture of the proper routing of teh linkage? I think the problem is in my installation of the choke as the linkage is pretty straightforward, but I thought the throttle would automatically open the choke plate?
