Bulbash
- May 22, 2012
- 332
Guys does anyone knows, when you adjusting 2 adjustment screws on rochester 2bbl carbs for a proper fuel / air ratio, does it applies to the moments when engine runs on high rpms as well as idle or it affects idle fuel / air ratio? Hopefully it does make sence since I'm a bit lost here with adjustments.
Thank you guys
Thank you guys
