1987 Sea Ray w/ Mercruiser 260 and Rochester Q-jet. Rebuilt carb to spec but encountered issue regarding full throttle operation. Discovered that when I open throttle while underway to 3/4 or better, the engine bogs down. However, if I disconnect the choke linkage it runs great. I’ve received a new divorced choke but after looking at the existing one I don’t believe this is the problem. I’ve opened the 2 air mixture screws at base of carb to 5 turns out. I am stumped. If not for the fact that I need choke for the initial cold start of the day I would not worry about it as I operate in both in Phoenix and San Diego where it is warm. I have no problem starting engine once it’s warmed up. Replace water/fuel separator. Where should I be looking?
