rockybottom
- Jul 31, 2009
- 4
My son has a 200 Yamaha 4 stoke. He keeps getting water in the carbs. put new water seperator's but still happining. has anybody had this broblem.?its a 2003 model. Thanks
very true rod bolt I didnt even think about thatcouple of issues here.
first and formost is there were NO carburated four stroke 200 ever imported to the US.
second is even if it were a carbed 2 stroke it would have NOTHING to do with a cylinder or head gasket.
the ONLY way to place water in a carb fuel bowl OR a Vapor seperator IS water in the fuel tank.
remember with todays fine ethanol blends large tanks can hold up to and over 20 gallons of water that is now a PART of the fuel and CANNOT be filtered with a standard water seperator.
however this homogeanous water/ethanol/gasoline mix will fall out of solution with heat.
then it collects in fuel bowls and VST tanks.
dunno what to do other than pump the tank, remove the fuel sender, mop the tank and make sure any deck fill orings or seals are intact and not cracking.
post us a model number so we know exactly what fuel and ign system we are disscussing.
