Re: Rodbolt Please you #1
most likly the VST filter.
however this engine also eats fuel pumps.
if you cant test the rail pressure then remove the seperator tank and clean the filter screen.
that tank can be removed without disconnecting the fuel lines.
use vasoline to aid in holding the VST oring in place during reassembly.
replace or rebuild the low pressure fuel pumps as well.
I know parts are rather difficult to procure in cuba.
