Roker arms instalation on a 4.3 l
VISH136
Hi Guys,
I have a bit of a problem with my 1998 larson flyer 4.3 l volvo penta. i blew a head gasket so i replaced it my problem is when i tighten down the rocker on the head i lose all compression but if i losen them just enough so that the springs dont go down i get compression back but when i do that the rocker arm guide (if that what its called?) its what the rockers sit on stay lose. I was wondering if there is any special way to set these.
Also if any 1 knows if there is a difference between a 96 and a 98 4.3l apart for the rocker arms which on a 96 does not have the guide. Are the lifters differnet?
Thanks in advance
zbnutcase
Re: Roker arms instalation on a 4.3 l
No lifters are the same. Are you giving it enough time for the lifters to bleed down???????
VISH136
What do you mean by bleed down? i put the push rods back on the lifters the put the roker arm support on the the rockers and with the Engine at TDC i tighten them down. Is that the correct way?
Bt Doctur
depends on the motor. 1 turn from "0" lash or their torqued to 20ft/lbs
